C45 7655 and 5655 saying provide payment or enter code
+ More Options
Posts
  • jmandassociates
    • Sep 2008
    • 186
    We have a C45, 7655, and a 5655 that were all removed from a place that had them connected to the automated credit card payment machines. Now that we have them at our place disconnected from their setup how do we disable this setting to change them back to a normal use copier.
    The 7655 says "provide Payment or enter code"
    The C45 and the 5655 say "Foreign interface device, to use machine services do one of the following access control device insert card, enter access code, insert money, insert key counter or appropriate action for your device.
  • Veedle
    Xerox Tech
    • Jul 2008
    • 44
    Hi,
    For the 7655 ( off the top of my head ), to disable the foreign interface you have to enter the UI Tools, select Accounting, Accounting enablement, and then Accounting mode. Or something along those lines...
    You may also need to remove the FDI board from the CCM board.
    You should then be able to use it normally.
    Don't know about the other machines.
    • jmandassociates
      • Sep 2008
      • 186
      I removed the FDI board, but when I try to make a copy it still says provide payment or enter code. I went into the Tools menu and the only thing in there is the group calibration. There are no other settings on there visible.
      • Veedle
        Xerox Tech
        • Jul 2008
        • 44
        Press login/out,
        Login as 'admin' with password '1111',
        press 'machine status' button,
        then from tools goto accounting...
        • jmandassociates
          • Sep 2008
          • 186
          Great thanks that worked perfect.
          • copy smart
            • Aug 2008
            • 11
            WC7655
            Hi Guys. Can you please tell me how to reset the User ID and the password on the centreware (web browser)
            Regards
            George
            Copysmart http://www.copysmart.com.au
            Blog http://copysmart.wordpress.com
            YouTube http://www.youtube.com/CopySmartCopiers
            Twitter http://twitter.com/CopySmartCopier
