Xerox 7835 Skewing
  • vishop
    • Jan 2011
    • 220
    Xerox 7835 Skewing
    Hi Guyz,
    Any procedures on how to deal with the skewing on this machine. Happening on all trays, and on both 80gsm and 200gsm.
    I dont see any mechanical adjustment on the skew.
  • Exok
    • Jun 2011
    • 750
    Re: Xerox 7835 Skewing
    Assuming that the skew is not coming from the scanner (skews on internal prints & test patterns), you would have to do a hard stop to see where the paper starts to skew in the paper path. I have not personally seen these machines have a skewing problem on prints from all trays. If the image is skewed on the paper there is not a lot of paper path that shares all 4 trays to where the image is applied at the transfer belt. You could possibly have something stuck in the paper path or uneven 2nd BTR pressure or a problem with the left door latching on one side.
    • vishop
      • Jan 2011
      • 220
      Thank You exok, ill have a check on that.
