I have a Xerox CM5005d that's making white line through prints, I'm suspecting it's from the transfer belt
Xerox CM5005d making white line through prints
Re: Xerox CM5005d making white line through prints
you can also remove the drum units & check the image on them,,, if the image is fine on the drums, but no good on the transfer belt, then a roller in the transfer belt assembly is bad -
