Does anyone know what the solution to magenta constantly spitting toner on the Ros Windows? What the permanent fix?
Xerox 252 spitting magenta toner
Tags: None
Re: Xerox 252 spitting magenta toner
Replace the filter (Ozone filter) located on the left, bottom and to the rear, just below and behind Tray 5, look for a small door. Also check the Magenta developer. Remove the M drum and check the thin piece of soft plastic that creates a seal between the drum and developer. If its old replace it.
Cheers and good luck!
