Xerox color 800/1000 fiery
  • Piper
    • Apr 2011
    • 76
    The fiery for our Xerox Color 800/1000 was corrupt after a power outage. We had to reinstall the System Software on it but Sys Software 3 DVD failed to read even after many attempts to have it read.
    After the server was restarted, it is giving the message: OPERATING SYSTEM NOT FOUND. What can we do to recover the server?
  • InterfaceP
    • Jun 2013
    • 488
    Re: Xerox color 800/1000 fiery
    When you started the operation it deleted and partitioned the HDD, so now its blank. If the install failed you need to start over, if you have the original disc try to reinstall, if its a copy try to burn another copy, sometimes you get a bad transfer.
    Good luck!
    • Piper
      • Apr 2011
      • 76
      The Server is okay now. The Disk Drive for Server was faulty.
      The DVD drive for the server stopped working after we inserted sys software DVD 3. So it couldn't read even after many attempts. We used an External DVD drive and in setup changed the Boot order to give the External DVD drive priority.
      We then loaded software without problems.
      Thanks.
      • The Grig
        • Jan 2021
        • 4
        Hi there, i have bought a Xerox 800 Press with a EX Print Server Fiery controller (qx-100 III) with no HDDs or Fiery media pack DVD's (they said that the printer is working ok). I can't call the seller because it was bought at an auction in Austria. I need the 3 dvd's ISO so i can make it run. Can someone help me?
