WC 7120 Reseat (K) Toner
  • SignPAL
    • May 2025
    I have 4 Black OEM Toner cartridges and none will show as seated. Any thoughts on why I am having this issue.
  • Flash
    • 378
    Re: WC 7120 Reseat (K) Toner
    Do you have the correct toner? There is metered and sold toner. If you still have the old cartridge see if it has a part number on it and compare it to the new one.
    • SignPAL
      Unfortunately I do not have the old toner. Is there only 1 type of ink you can use now or do you have to fit the correct toner to the machine, when ordering? Is the a way to convert the machine to accept the other type of toner?
