I have attached an image of what it is doing. If feel that it is electrical and possibly the wall voltage. Xerox tech seemed not to want to entertain that possibility, because it is rated for +/- 10% of power.
There is an ESP that is hooked up. The voltage that I am reading at idle is 116 VAC and low 114 VAC during copying. They say the first sheet normally comes out fine and the rest of the copies start to show the issue.
I have flashed the firmware, but not much else. I am stuck on low voltage, but if you have seen issue, please let me know. As you can see in the example, the pattern is not constant, so I would not consider it a drum, DV or other physical component.
Any help would be appreciated.
