xerox 700 magenta spots
  • lion_heart
    • Jun 2014
    • 174
    good day, xerox 700, on my prints i am getting these funny random magenta spots, i cleaned any dust i could have seen in the machine by taking the fuser out and other stuff, but still seeing these spots, pics attached. please help.IMG_2761.JPGIMG_2762.JPGIMG_2763.JPGIMG_2764.JPG
  • bojans
    • 1313
    Re: xerox 700 magenta spots
    I believe that you have contaminated developer, but also it could be bad drum.
    First swap drum places, then check developer and toner.
    I had couple situations with toner. It was exposed to heat and became melted and grainy.
    • Jake2o
      • Dec 2007
      • 325
      What appears if you print a colour with no magenta in it so a 70% cyan page?
      If it comes out on that page then the Developer housing is faulty, if it doesn't appear then drum or just the developer.
      If the Dev housing is anywhere near EOL on the HFSI report then change it anyway.
      Just a quick test swap over the drums for M & C do the colour spots change?
      • lion_heart
        • Jun 2014
        • 174
        swapped drums, same issue, guess it's a developer problem, have an used magenta developer will try that. thanks
        • Garysg
          • Apr 2014
          • 5
          [QUOTE=lion_heart;513714]good day, xerox 700, on my prints i am getting these funny random magenta spots, i cleaned any dust i could have seen in the machine by taking the fuser out and other stuff, but still seeing these spots, pics attached. please help
          Definitely drum or developer
          • lion_heart
            • Jun 2014
            • 174
            seems like you might be right, changed toner, after about 100 prints the spots cleared up. thanks a lot.
            • drewzif
              • 101
              I have seen this issue with refurbished drums. The drum tends to leak toner, this builds up on a metal shelf below the drum unit and when it becomes too much on the shelf spills onto the belt for transfer to your prints.
              Is there buildup of toner on the metal shelf under the drum?
              • Jake2o
                • Dec 2007
                • 325
                I've seen similar faults caused by drums, they don't create a seal against the Dev housing and then the toner can fall out, refurbished ones still don't create a seal properly as people usually only change the drum and not certain bearings, springs or cleaning blades.
