Getting Error Scanner needs service on Xerox WC 5655
  • Krunal
    • Oct 2015
    • 64
    [Error Code] Getting Error Scanner needs service on Xerox WC 5655
    Hello everyone,
    I am getting error code 14-110 & 14-730 on my Xerox WC 5655.
    Kindly help.
  • Krunal
    • Oct 2015
    • 64
    Re: Getting Error Scanner needs service on Xerox WC 5655
    Anybody knows how to troubleshoot this error ?
    • xtrain
      • Dec 2012
      • 233
      Edoc shows 14-110 scan carriage not home. May be scan motor rubber drive element damaged.14-730 says scan control pwb inoperative. May be harness to scanner and pwb damaged.
      • Exok
        • Jun 2011
        • 750
        One of the first codes you get when the Low Voltage Power Supply has a problem are scanner codes. Check that you have all your LVPS outputs present.
        • xcopytech
          • Aug 2006
          • 1792
          Check for burned resistor on CCD PWB.
          • Krunal
            • Oct 2015
            • 64
            Still getting the same error. Can anyone help
            • Krunal
              • Oct 2015
              • 64
              It doesn't appears while machine ia idle or kept on for few hours. It occurs after making some copiea
              • Romano
                • Jun 2016
                • 2
                I have a document:
                Troubleshooting RAP 24vdc
                Send?
                Need email address
                • Krunal
                  • Oct 2015
                  • 64
                  Kindly send me at krunal_shah787@yahoo.com
                  Thanx.
                  Sent from my GT-I9300 using Tapatalk
                  • Romano
                    • Jun 2016
                    • 2
                    I sent
                    • Krunal
                      • Oct 2015
                      • 64
                      Yes i received it. Is it the same mentioned in service manual. I have tried everything mentioned in service manual.
