Version 73 firmware and NVM defaults
  • n00tch
    • May 2016
    • 5
    [Misc] Version 73 firmware and NVM defaults
    Hi All!
    I am a system analyst and network engineer. I frequently do firmware upgrades in the field and have noticed something quite a bit odd when going to version 73 on ConnectKey devices . The "Print Supplies Report" button that used to be under the Supplies tab in Machine Status goes poof. I've poured over the RUI and looked at the machine settings but I cannot find where to enable this button again. I'm thinking that it is a NVM setting at this point. Anyone have any insight into this or other defaults that may have changed?
    On a side note, anyone have a comprehensive list of NVM settings and what they actually do? Xerox does not make this information easy to find.
    Thanks!
  • jhalfhide
    • Apr 2015
    • 451
    Re: Version 73 firmware and NVM defaults
    I'm installing a new 73 machine tomorrow. Will scout it out and see if I can locate it.
    • n00tch
      • May 2016
      • 5
      Thanks for looking! I get so frustrated with Xerox sometimes and how tight-lipped they are with info... even to their own cores!
      • jhalfhide
        • Apr 2015
        • 451
        They're very much a "computer says no" organisation that take some getting used to.
        • jhalfhide
          • Apr 2015
          • 451
          Working fine for me on a new 7220i running 73.030.075.34540
          • n00tch
            • May 2016
            • 5
            Thanks for looking. Was this machine deployed on version 73 firmware from the factory or was it an upgrade?
            • jhalfhide
              • Apr 2015
              • 451
              Deployed, although we have also upgraded two field machines to 73 and they have the button.
              • n00tch
                • May 2016
                • 5
                Last question, I swear. Were the field upgrades done using the tool or were they done manually?
                Thanks again for all the help!
                • jhalfhide
                  • Apr 2015
                  • 451
                  Both were forced alt boot's done due to problems.
