Have a xerox 700, noticed that the registration seemed to be moving earlier some prints up and some down, turned machine off few a few hours after turning back on, every paper that i try to print jams at registration, heavy card stock seem to go through at times, now even that jams at the fuser. any ideas?? thanks
xerox 700 paper jams on registration
Tags: None
Re: xerox 700 paper jams on registration
Lion Heart - Need some info here to help. What weight or type of paper are you using? Is that what you are confirming when loading paper? What are the Jam Codes or Engine Fault Codes? When you say registration is that from tray, if so which one or is that inside the machine prior to 2nd Bias Transfer Roller or fuser area? When it jams where does it jam, what happens to the paper when it jams - folded like accordian, skewed, stalled, caught fire? Just need some info to better help you resolve this issue.
Hope this helps -
Hope this helps
Folding like an accordian in the registration assembly, it's the gear, looked at it, the middle is worn down like a hooker working a double shift. will try express ship one of them, thanksComment
