xerox 700 registration
  • lion_heart
    • Jun 2014
    • 174
    Good day, have an interesting problem, all the paper that is being fed through my 700 comes in at a slight angle which makes my prints skewed. Attached is a photo of the paper when it is as far as the fuser. I have moved the registation assemblly back and forth from each angle still the same feed issue. Any suggestions? thanks
  • Flash
    • 378
    Re: xerox 700 registration
    How old is the 2nd btr?
    • xtrain
      • Dec 2012
      • 233
      Place a shim under each of the plastic fins that lift the nip release roll shaft. This will allow it to lift a little more and allow the paper to be driven by the second BTR roll, and should fix the skew.
      • lion_heart
        • Jun 2014
        • 174
        Good day, I am trying my best to figure out what that is. what is the nip release roll shaft? the lime green lift that has (2a) on it? do you mean the plastic to both ends? thanks
        • xtrain
          • Dec 2012
          • 233
          The nip release roll sits above the registration roll and presses the paper against the registration roller. It lifts as the paper is registered and leaves the registration area and arrives at the second BTR roll for image transfer. If the nip release roll is not parallel to the registration roll, or does not lift enough, the paper can skew going to the second BTR roll.
          • mickey singh
            • May 2014
            • 93
            Check registration gear first mate! Common fault for then to deteroite
