C75 Shuts down
  • InterfaceP
    • Jun 2013
    • 488
    C75 Shuts down
    I have a C75 that starts up just fine but when I try to print to it it turns off. Any ideas?
  • jhalfhide
    • Apr 2015
    • 454
    Re: C75 Shuts down
    Strictly when you print, or when you do other things. I had one randomly turn off when it was being used for anything. Heard a weird crackling sound and it turned out to be a high cap tray sensor that had been damaged. This was shorting against the frame.
    Failing that, I'd be voltage testing boards but then that would only make sense if it switches off when you ask anything of it (print or copy)
    • InterfaceP
      • Jun 2013
      • 488
      Re: C75 Shuts down
      That makes sense. Ill check it out Thanks!
