Xerox WC 5765
  • Krunal
    • Oct 2015
    • 64
    Xerox WC 5765
    Hello everyone, Can anyone guide me whether scanning in wc 5765 works with usb A-B cable ? I am using it presently with direct printing from usb and I want to configure scan to pc.
    Thanx.
    Sent from my GT-I9300 using Tapatalk
  • Mukasa
    • May 2015
    • 178
    Re: Xerox WC 5765
    Thanx.
    Hello,
    scan to pc you need enthernet network communication b'se you need to confingure the SMB between the machine and the pc
    • Krunal
      • Oct 2015
      • 64
      Re: Xerox WC 5765
      Have done it. Thanx. But not getting any solution to scanner needs service error on xerox elwc 5655.
      • JrTech
        • Jun 2013
        • 217
        Re: Xerox WC 5765
        Krunal,
        Could you send the error code for the Scanner Needs Service. Press Machine Status - Messages - All Messages - Error log. The last poster was correct in you need an ethernet connection to Scan to PC. Back in the day you could use the USB connection but needed a program to retrieve the scan ie Paper Port. You can set up the scanning to scan directly to your computer thru the ethernet as I am sure you are plugging in the USB everytime you leave and come back. Set the IP address to your computer to 1 number off the machines IP. Example your Xerox 5765 is 192.168.1.101 now set you computer under LAN Connection to 192.168.1.102. Now from here you can see the machine in any browser by simply typing the machines IP address. From this point you can set up the Network Scanning. From this point go to Business Services and Digital Printing Solutions and download the Analyst Guide. This will walk you thru of setting up a folder on your desktop or a drive to then point to your desktop, set up permissions. You will be up and running for Network Scanning in 10 mins.
        Now as for the Scanner Needs Service that has nothing to do with Scan to PC or Network Scanning that is a mechanical error not a network issue. If the scans do not go thru the machine is defaulted to print out a Scan Fail report and will give you a 3 digit error code and a short description like Username/Password did not match or Unable to connect to Server.
        Hope this helps
        • Krunal
          • Oct 2015
          • 64
          Re: Xerox WC 5765
          14-560 & 14-563
