Xerographic Fault
  • riyas30
    Xerographic Fault
    I Have Xerox 5755 Machine Few days i have some error xerographic fault then i changed the new 4b unit but still i have that problem. When I Start the machine on morning then i do quick restart some time and remove 4b unit then insert and leave them machine 15 min then start machine then machine work properly on that hole day again next day i have that problem what i do...?
  • JrTech
    • Jun 2013
    • 217
    Re: Xerographic Fault
    What is the error code that you are getting? Press machine status - faults - active messages or fault history. There will be a five digit code? Example 01-123 format.
    Hope this helps
    • babujoshi28
      I am indian and i speech only hindi pls help
      Sent from my Che1-L04 using Tapatalk
      • babujoshi28
        Xerox 5755 geographic failt and paper jam left door
        • andywong90
          • Mar 2013
          • 110
          Hello,try chg the cleaning motor for main charge.this motor located at rear main motor
          • Manuas
            • Nov 2016
            • 20
            Try another drum. Clean transfer unit. Remove ALL trays and BE SURE NO paper or debris behind trays and up in top areas. log into diags mode and clear codes then let it fail then go back in and look at code. Trace code and you will find problem and fix.
            • Exok
              • Jun 2011
              • 750
              Reporting your fault codes would be a help in troubleshooting. For example, if the xerographic faults are occurring with 9-060 faults, you could have a faulty High Voltage Power Supply or poor connection on the board.
              • aims
                sir i have this issue then i changed 4b unit (blue handle unit) and also i have installed stabilizer but stll now i have these issue with error code 9-560 what to do please help me
                • THKUVESH
                  Xerox 5755 foult code :- 03-480 power supply foult
                  03-777 sip recovered form an uncontrolled power loss
                  how to solve this problem dear frds.......
                  May i change new power supply unit but the action is continued...........same foult
                  and service full machine.......at one by one all part.....
                  And i replace the power supply change with other machine that are work perfect and complete
