Xerox XD-105f
  • Fierhawk
    • Jul 2025
    Xerox XD-105f
    What causes the Xerox XD-105f to not add toner? The only way I can add toner is to pull out the toner cartridge and add toner manuelly. Any help appreciated, thank you.
  • paul bristol uk
    • Nov 2005
    • 51
    How are you adding toner manually? IIRC it has a TD cart. Otherwise check your toner motor has not broken its gear.
    • Fierhawk
      • Jul 2025
      I am having to pull the toner cartridge out and turn the gear on the back of it to add toner. Not sure what IIRC is?
      Thanks.
      • paul bristol uk
        • Nov 2005
        • 51
        Apologies for the abreviation IIRC= If I Recall Corrrectly.
        • bernyb
          • 42
          Xerox XD-105f
          The drive gear could be broken. The stepper motor could be bad. I have seen both those problems. Make sure you are getting voltage to the stepper motor. If so motor is bad and replace.
