Strange Docucolor 252 losing cyan across part page
  • hairybathplug
    • Jul 2025
    I wonder if you guys can help? I have a Dc252 losing cyan across the whole lenth of the page in two stripes. The dead areas dont move. I have chaged the imaging drum, cleaned the optics above the imaging drum and the developer drum is turning and apperes to have toner down the whole lenth of the worm drive. The rest of the page is fine on cyan and all other colours are correct. Is there anything im missing?amp026.jpg
  • Mukasa
    • May 2015
    • 178
    Re: Strange Docucolor 252 losing cyan across part page
    Originally posted by hairybathplug
    I wonder if you guys can help? I have a Dc252 losing cyan across the whole lenth of the page in two stripes. The dead areas dont move. I have chaged the imaging drum, cleaned the optics above the imaging drum and the developer drum is turning and apperes to have toner down the whole lenth of the worm drive. The rest of the page is fine on cyan and all other colours are correct. Is there anything im missing?[ATTACH=CONFIG]33683[/ATTACH]
    Hello,
    Confirm if this is a photocopy or a print copy.
    Godfrey
    • wideformat
      Thanks for the reply its a test print, its the same copy or print
      • wideformat
        * I apper to have two log-ins on differtent computers
        • Jake2o
          • Dec 2007
          • 325
          Do a solid print in just cyan,
          or print out this test page - http://www.jtek.co.uk/images/pdf_doc...2015020301.pdf
          and post it please.
          I have a feeling that if the missing bit is about 3 -4 inch in from one side and goes the length of the page it's probably ROS unit that needs a clean.
          • hairybathplug
            Thank you for your reply
            Im looking at it now and there appers to be toner dust on the upper side of the ROS window........test.jpg
            • Jake2o
              • Dec 2007
              • 325
              It seems like there might be a lot of dust on that ROS unit.
              Clean it off and lets see what happens
