xerox 5855 scanner fault
+ More Options
Posts
  • efe311
    • Oct 2008
    • 114
    [Error Code] xerox 5855 scanner fault
    My xerox wc 5855 have errore scanner fault
    Any body can fix it
  • Flash
    • 378
    Re: xerox 5855 scanner fault
    Check the fault codes.If you are getting a 05-959 code replace the SPDH lift home position sensor.
