93-564 Error Code
  • acsolutions
    replied
    Re: 93-564 Error Code
    I have a 9303 with a error 93-556. It say print head reservoir I replaced the #4 print head all the umbilical and the melting reservoir I swapped the #4 and #2 with the same code. I did purge the umbilical, reservoir and printhead before machine came to ready. I'm looking to replace the reservoir again. Any suggestions! Thanks
  • prismtech
    replied
    Originally posted by tekkie
    I have xerox Colorqube 9303 with the error code 093-564 which indicates yellow printhead reservoir level problems.Anyone had similar issues on this model with similar code
    Install a new upper umbilical, PL 91.20 Item 10 and a new ink reservoir, PL 93.10 Item 10.
    Start with reservoir replacement. This has always fixed it for me.
    Unless you are techie. This replacement is not possible.
    Post here for more details or part numbers.
  • tekkie
    started a topic [Error Code] 93-564 Error Code
    93-564 Error Code
