Chase Xerox 5765 add rollers
  • Zahid khan
    • May 2016
    • 72
    Xerox 5765 two rubber rollers in the adf is melted how I can change it.
  • Mukasa
    • May 2015
    • 178
    Re: Chase Xerox 5765 add rollers
    Switch off the electricity to the machine, Disconnect the power cord from the customer supply while performing tasks that do not need electricity. Electricity can cause death or injury. Moving parts can cause injury.
    1. Remove the feed assembly,
      Take care during this procedure. Sharp edges may be present that can cause injury.
      1. Open the DADH top cover.
      2. If installed, remove the rear wall,
      3. Remove the DADH rear cover,
      4. Remove the feed roll assembly,
      5. Remove the feed assembly,
        NOTE:
        40-90 ppm machines have an in-line connector between PJ184 and the document present sensor. Disconnect the in-line connector before removing the feed assembly.
      CAUTION Be careful when the self tapping screw is installed into a plastic component, refer to
      The replacement is the reverse of the removal procedure.
    2. Remove the input tray assembly,
      1. Remove the DADH,
      2. Remove the feed assembly,
        NOTE:
        To release the tension of the drive belts,
      3. Remove the input tray assembly,
      1. The replacement is the reverse of the removal procedure.
      2. Perform the feed motor and the CVT motor, belt tension adjustment, .
      CAUTION Disconnect the ground harness from the static eliminator before the input tray assembly lower cover is removed, .
    3. Turn the input tray assembly upside down. Remove the relevant cover:
      • (35 ppm) Input tray assembly lower cover,
      • (40-90 ppm) Lower cover (right), and Lower cover (left),
    4. Remove the exit roll assembly, .
    CAUTION Take care when installing self tapping screws into plastic components, refer to
    The replacement is the reverse of the removal procedure. Make sure the spacers and E-clips are installed correctly,
    • Zahid khan
      • May 2016
      • 72
      Bundle of thanks
