Light Streak Black Only Workcentre Pro 40
  • Dukeman
    • Jul 2025
  • adriansto
    • 2387
    Re: Light Streak Black Only Workcentre Pro 40
    Old machine.
    First is to check / replace black developer assy.
    • Dukeman
      Originally posted by adriansto
      Old machine.
      Thanks for the info. Can you please tell me where to look for that assembly to inspect it? I've replaced the drum cartridge, toner and 2nd BTR Cleaner already. But I don't have a service manual to locate that unit.
      Thanks!
      • adriansto
        • 2387
        Thanks!
        It is under the black drum module but a lot of things to disassembly.
        Send me mail at stoadis@gmail.com for service manual.
        • Dukeman
          Done. Thank you!
          • Exok
            • Jun 2011
            • 750
            I haven't worked on one of these, just the 73xx and on but I imagine they are not too different (I have worked on one 3535). Not sure if the Pro 40 has a laser unit or LED array. With a laser unit, you may have dusting on the laser window causing light streaks. With the LED array set up you may have some bad segments or just poor connection. I had a 74xx where I just swapped LED array from one color to another and the problem went away.
            You may also have chunks of clumped toner stuck in your developer housing. There is a metering blade that limits the amount of toner/ developer on the magnetic roller. If a chunk gets stuck between the blade and the roller, you'll get strips around the roller with less toner / developer causing light streaks. You can try using something very flat to swipe between the 2 to get it free but it may come back. You may need to take the housing apart, clean it well and install fresh developer.
            A more rare thing would be a possible problem with your 1st BTR roller located inside the transfer belt assembly (1 for each color KCMY).
            • Dukeman
              Fixed it. Turns out I needed to run the cleaning wand over the laser/led window below the drum cartridge. There was a lot toner in there and that cleaned up the prints. Thank you for all of your help, it pointed me in the right direction.
