Hi, There is probably an obvious answer but I need to be sure. Can a customer hook up an actual USB disk drive to a WC7545? I'm not talking a thumb type drive but an actual rotating, Terabyte sized disk drive? The goal is to use the drive as an archive for large files hence to large size.
If I can't use the 7545 port, can I hook it up to a PC, share it and then scan to it?
I've never tried either scenario in real life but both seem doable on the surface.
Happy Thoughts
Karl
Happy Thoughts
Karl
