Xerox 5765 altboot
  • Zahid khan
    • May 2016
    • 72
    Xerox 5765 altboot
    I copy this folder into sub and insert into Xerox sub port but altboot not work
  • lilleputte
    • Jan 2013
    • 154
    Re: Xerox 5765 altboot
    Try with another pendrive. AltBoot and then the DLM file insde the folder
    • Zahid khan
      • May 2016
      • 72
      i used 4 different pendrives
      • Exok
        • Jun 2011
        • 750
        What is wrong with your machine that you are attempting to do an AltBoot?
        What is the software version that you are trying to install? (I can't read the screen in your photo, too small)
        • Zahid khan
          • May 2016
          • 72
          i am installing the same software already installed in machine.the machine does not copy only print.the scan copy on upper bar does not appear when I go to copy menu.it only beeps.
          • Exok
            • Jun 2011
            • 750
            Try a forced altboot.
            On a thumb drive, create a folder named "altboot".
            Inside the folder place the DLM file (machine software)
            WorkCentre 5765/5775/5790 File Download
            Link above is software available at xerox.com
            Create a text file with no data in it.
            Name the text file, "FORCED_UPGRADE" all caps just as it appears.
            Remove the file extension from the text file, ".txt"
            Place the FORCED_UPGRADE file in the "altboot" folder with the DLM file.
            Power off the copier. Insert the thumb drive in one of the USB ports in the back of the copier.
            Power the copier on. Your machine should enter "software upgrade" mode in a few minutes.
            • andywong90
              • Mar 2013
              • 110
              Hello best fren,u got wc 5665 pas diagnostic tool for upload nvm? Thanks
              • andywong90
                • Mar 2013
                • 110
                Pws diagnosic tool for upload nvm
