xerox 4110 fault 012-322
+ More Options
Posts
  • vmx12
    • Sep 2007
    • 55
    Don't have much on finisher. Anyone help out with a FIP?
  • InterfaceP
    • Jun 2013
    • 488
    Re: xerox 4110 fault 012-322
    Punch move sensor fail.
    Enter Component Control [14-070] and [14-072], Puncher Move Motor ( PL 21.5), alternately. Select Start.
    • Exok
      • Jun 2011
      • 750
      Check the wire harness going to the punch unit in the back of the finisher. Over time as the punch unit moves back and forth, this causes stress on the wires and eventually can cause one or more of the wires to snap near one of the tie wraps. If you find a broken wire, remove the plastic tie wrap and splice the wire back together.
