Colorqube 9301 Harddisk replace
  • kurbads
    • May 2017
    • 26
    #16
    Re: Colorqube 9301 Harddisk replace
    I apologise for overwhelmingly long post. I hope I did not scare anybody off with my boring comments.
    I was just reporting everything in the order of discovery with lots of assumptions which where designed to show nothing else but my confusion.
    I would really like to know if anybody has any suggestions. I do have people around the printer there who I can ask remotely to try something if there is a suggestion get there at end of November.
    Given the HDD problem is fixed, how could I fix the preheat problem and the possibly related paper problem.
    What I did not mention was that during one of the reboots while printer was printing but crushing after one sided of double sided page possibly due to SSD, it asked for yellow colour brick which I supplied but to my surprise it did not zoom in. I did notice that it has been swallowed later but just before leaving the office to airport, I looked at it again and noticed that there are yellow wax shavings in the tray.
    Is it possible that it sees something in the ink area? I assume the preheater is what melts inks for use while printing. Could it be possible cleaned out? How to take it apart please?
    Thank you!
    • prismtech
      • May 2014
      • 199
      #17
      89-520 Indicates the stance sensor on the preheat assembly has failed. This is a common failure on these units.
      Replace pre-heat assembly:
      Xerox ColorQube 92xx 93xx Registration Preheat Assembly 801K37710 604K54870 | eBay
      If you look at the current pre-heat assembly my guess is the front flag gear has stripped on the shaft. Most of the other gears on the pre-heat assembly will be close to failure at this point. Replace entire unit.
      Sent from my SM-T530NU using Tapatalk
      • prismtech
        • May 2014
        • 199
        #18
        As for the paper issue, are you running European a4 or 8.5x11? Change the paper size of the tray to reflect the actual paper size.
        • prismtech
          • May 2014
          • 199
          #19
          Replacing the pre-heat assembly is a 5 minute job. If you haven't done it before I will post a YouTube video showing how to get it out. It's only difficult if you don't know what screws to pull and the fact you have to pop the left side open to extract the horizontal feed assembly.
          • prismtech
            • May 2014
            • 199
            #20
            And the pre-heater has nothing to do with melting ink. It actually pre heats the paper before it hits the drum. It also shifts the paper for registration.
            • kurbads
              • May 2017
              • 26
              #21
              Thank you and please, please do. I would need the video instruction.
              • kurbads
                • May 2017
                • 26
                #22
                If you could point out in instruction which parts to look for to see the damage and check if it is bad before I order replacement. Thank you!
                • kurbads
                  • May 2017
                  • 26
                  #23
                  The paper size is not a problem. There is A4 <> Letter paper substitution set up in settings.
                  • kurbads
                    • May 2017
                    • 26
                    #24
                    Is this the video? YouTube
                    • prismtech
                      • May 2014
                      • 199
                      #25
                      Not the video but I will post one this weekend.
                      • prismtech
                        • May 2014
                        • 199
                        #26
                        The correct piece to order is the entire pre-heat assembly. Just trying to replace bits and pieces of it is hopeless. Once the nylon gears start to shred they all go.
                        • kurbads
                          • May 2017
                          • 26
                          #27
                          I ordered one. A used one from the listing you quoted. Can you advice how many warmups does it survive? Could it be what contributed to its premature death the fact that printer was resetting itself at midnight and reheating inks every day?
                          • prismtech
                            • May 2014
                            • 199
                            #28
                            How many sheets on the unit you have? They tend to get brittle gears and stance shutter at 750,000 copies. Sometimes you just have bad luck and they let go sooner. I will point out in the vid what to check for.
                            The resets at midnight wouldn't cause this piece to fail. It dies due to copies and age.
                            • prismtech
                              • May 2014
                              • 199
                              #29
                              If you look at 89-520 in the service manual figure 2. That sensor cap that the arrow points to always de-bonds from the shaft. Once it has let go your finished.
                              • prismtech
                                • May 2014
                                • 199
                                #30
                                I'm running behind. Will post the video later this week....
