Newbie questions for Xerox DC 250 with fiery and booklet device
  • lau82
    • Jun 2025
    Hello,
    I've bought Xerox dc 250 and I have few questions:
    I want to print from my Mac with El Capitan (10.11.5 version), I don't have LAN port, and my router is far away from Xerox so I don't want to put one long network cable.
    1. If I buy usb to lan adapter and lan - lan cable, can I make network Mac - Xerox? Or should I buy one more router with access point to connect Xerox to router via lan - lan and mac to router via wi-fi?
    2. There is some dongle, usb wi-fi adapter, but Xerox know to take print information from usb?
    3. I see at back of Xerox, there is also a port like square, all home printer have this port, I take a printer cable, connect with my mac but nothing happend. Try add new printer and mac doesn't see Xerox.
    And one last question for drivers:
    4. On Xerox page, there is no drivers for my mac, but on same site at specifications, they tell that have mac drivers. What should I do?
    Thank you very much.
  • adriansto
    • 2384
    Re: Newbie questions for Xerox DC 250 with fiery and booklet device
    Descarca sistem administration guide from xerox website si citeste-l.
    Fiery comunica cu reteaua printr-o aplicatie numita comand workstation.
    Exista versiunea pt PC si versiunea pt MAC.
    Ar trebui sa ai acest soft in cd-urile ce vin cu Fiery
    Atita timp cit exista o legatura net intre Fiery si calculatorul pe care este instalat Command Workstation ar trebui sa functioneze.
    Portul usb B type este pt service asa ca nu ai treaba cu el.
    • lau82
      Multumesc Adriansto, ma bucur sa gasesc pe cineva "de prin imprejurimi" pe aici.
