WC-7845 - Fax forwarding
  • MHeon71
    • Oct 2008
    • 489
    I have connected a WC-7845 to scan to email and it works fine. I try to fax forward to an email and I get an authentication error. I have gone to Services\Faxes\Setup and went to the Forwarding tab to set it up. Is there something that I am missing?
    Thanks for any help.
    Mark
  • xeroxsharp
    • Nov 2008
    • 270
    Re: WC-7845 - Fax forwarding
    Mark
    If you set fax forwarding OK, it must work.
    OR
    Try to load latest FW
    • MHeon71
      • Oct 2008
      • 489
      Thanks for your suggestion Xeroxsharp. It is at the latest firmware. The solution was simple as I thought it would be. Fax Forwarding was setup, but within the SMTP authentication settings, I did not select the bullet that would allow for fax forwarding to work.
