WorkCentre 7428 Fault/Error 116-324
  • dradisic
    • Jun 2016
    • 11
    [Error Code] WorkCentre 7428 Fault/Error 116-324
    Dear all,
    I need your help regarding error on WC7428, I'll try to explain what happened,
    The device is reset for a moment by himself and no longer wanted to boot a system error 116-324 occurs and it stuck. I suspect the problem with the hard drive.
    My question is whether the system can be cloned from another of the same device and put it on a new hard disk, whether it will work or what other steps.
    Thank you in advance and best regards,
    Darko
  • shinchan
    • May 2011
    • 195
    Re: WorkCentre 7428 Fault/Error 116-324
    Originally posted by dradisic
    Dear all,
    Darko
    from WC 123 manual. Usually the error code shows the same information.
    116-324 System Detected An Error RAP
    Unusual CPU processing occurred.
    Initial Actions
    Refer to BSD 16.1.
    Power OFF/ON
    Procedure
    Pull out and insert or replace the DIMM (PL 9.2).
    Replace the ESS PWB (PL 9.2).
    I guess you can try cleaning the DIMM (RAM) using contact cleaner.
    If you think it is HDD problem, try swap the HDD.
    Hope it helps
    • xeroxsharp
      • Nov 2008
      • 270
      try to use special boot method - SPOOL reset for corupt print job
      -remove network cabl and POWER OFF the copier
      - with network cabl off, power on the copier while you are holding ( 6 , STOP and POWER SAVE ) keys until your copier is ready
      Try to make a copy from any tray
      Connect network card back and try to send next print job ( not the same job as before )
      • dradisic
        • Jun 2016
        • 11
        Hi mate,
        Thank you for replay,
        I tried following your instructions but doesn't work, the same happens and now I have another number of error message: 116-331
        Do you know what that means?
        I have two of the same machine and I checked HDD replacement parts, correct it, check memory, also correctly,
        Can I change cards with EPRROM and card with battery, that does is safe because I'm afraid it does not spoil the correct machine?
        When replace the entire drawer board with complete electronics, device works correct.
        Darko
        • shinchan
          • May 2011
          • 195
          I checked the manual,
          you should try to do hdd initialization.
          special boot procedure
          1. power off machine.
          2. hold down 4, stop and power save button
          3. power on the machine while holding those buttons.
          4. release the button after the machine is ready.
          hope this helps
          • dradisic
            • Jun 2016
            • 11
            hope this helps
            Hi mate,
            Today I tried your key combination, the same is happening and same error, 116-324, any other advice?
            Do you have a list of key combinations for various functions?
            Regards,
            Darko
            • shinchan
              • May 2011
              • 195
              Hi mate,
              Regards,
              Darko
              from my WC 123 textbook
              Initial Actions
              Refer to BSD 16.1.
              Power OFF/ON
              Procedure
              check out the special boot in the attachment, read it carefully.
