xerox wc 570 fault code 003-318
  • Mukasa
    • May 2015
    • 178
    [Error Code] xerox wc 570 fault code 003-318
    Hello,
    I need your input Guys. xerox 570 fault 003-318
    As per the RAP, PO/PO, upgrade / reload Software, IIT and ESS PWB replacement does not help. The RAP is very poor and does not give any BSD or further help. As per symptoms, the Scanner does not initialise and the Exposure Lamp does not come on. That pointed to the IIT power.
  • adriansto
    • 2387
    Re: xerox wc 570 fault code 003-318
    And did you changed the IIT LVPS ?
    • Mukasa
      • May 2015
      • 178
      I have not yet changed it ,can you send me its part numbers please.( 240V).
      Muks
      • adriansto
        • 2387
        105E19210
        • Mukasa
          • May 2015
          • 178
          105E19210
          Thanks adriansto.
          Muks
