WorkCentre 7125 . Cant login to CentreWare IS, but front panal access is ok ?
  • mbilgrav
    Hi ,
    This is my first post in this forum - HelloWorld!
    I go some WorkCentre 7125 on offices. They are all just connected to windwos print server and Work just fine ...
    I am originally trying to disable the Smart eSolution, and my printers doesnt have internet access, and I want to disable the error message I get on the display, as it really isnt an error ... But users get confused about it.
    I understand I need to do this via the embedded web agent called CWIS - short for CentreWare Internet Service.
    I can acces the webpage on but when I click on PROPERTIES and gets pormpted for username/pass, I cant login.
    Funny part is, that I do actually KNOW the password, and I can login via the printers front panel !
    Go figure ..
    How can I reset the CWIS user/pw or how can I disable Smart Esolution `to not enrolled ?
    please advise, and please explain, as this will be my first time here, but I am a tech-dude allthough .,..
  • Iowatech
    Not a service manager
    • 3930
    Re: WorkCentre 7125 . Cant login to CentreWare IS, but front panal access is ok ?
    While we wait for smarter people to show up, I do have a suggestion you may wish to consider -
    If I remember correctly, the user name and password for Admin mode in CentreWare should be the same as you use to get into Admin mode from the machine's op panel.
    I don't have a PWS anymore, so that's the best I can do.
    Sorry if that was a waste of time.
    • mbilgrav
      Hiya,
      Thanks for your reply.
      This is just what I try, but with no success.
      Eventhough I can successfully login into the printers panel, I cant use the same credentials for the CWIS login.
      I am not sure if this is faulty/buggy, or if its evenpossible to have seperate credentials.
      If I take another angle at this; Who can I reset the CWIS password or even the software ?
      Or can I edit the SmarteSolution setting from the panel ?
      • thomfish
        • Jul 2014
        • 101
        Admin and CentreWare password should be the same. Try reset password from service mode and then use new password to login. I am not sure if it helps but it's worth to try.
        Also input default admin password and then try.
        • Pyth
          After 3 wrong user/pass you need restart.
          For 712x family you can reset pass from service mode.
          For 722x you need Xerox support.
          Use sag (system admin guide) 712x for correct user/admin in cwis.
          Sent from mTalk
