Xerox scan to pc
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    #16
    Re: Xerox scan to pc
    Try the I.P. address of the PC, NOT the hostname of the PC. Our experience with Xerox is their machines don't play well with SOHO routers for using hostnames. Xerox requires a "real" DNS to be running on the network for hostnames to work . Stupid.
    It does not matter how slowly you go as long as you do not stop. –Confucius
    • guitar9199
      • Sep 2016
      • 1100
      #17
      Originally posted by andywong90
      Sorry,what mean switching it back netbios tcp/ip over? I only using smb for scan to pc.problem is something fail to scan .
      Windows 7, 8 and 10 are using NetBIOS over DHCP as a default. For some reason Windows SMB doesn't seem to like that type of protocol, so switching it back to "NetBIOS over TCP/IP" sould allow for network discovery and SMB scan to file to work correctly.
      You can manually configure WINS by following these steps:
      1. Access the Advanced TCP/IP Settings dialog box for IPv4 and click the WINS tab as shown in Figure 21-4. In the WINS addresses, In Order Of Use panel, you can specify the IPv4 addresses of each WINS server that is used for NetBIOS name resolution. Click Add if you want to add a server IPv4 address to the list. Click Remove to remove a selected server from the list. Click Edit to edit the selected entry.
        Figure21-4 configure WINS resolution for NetBIOS computer names on the WINS tab of the Advanced TCP/IP Settings dialog box.
      2. You can specify multiple servers, which are used in order, for WINS resolution. If the first server isn't available to respond to a NetBIOS name resolution request, the next WINS server on the list is accessed, and so on. To change the position of a server in the list box, select it and then click the up or down arrow button.
      3. To enable LMHOSTS lookups, select the Enable LMHOSTS Lookup check box. If you want the computer to use an existing LMHOSTS file defined somewhere on the network, retrieve this file by clicking import LMHOSTS. You generally will use LMHOSTS only when other name resolution methods fail.
      4. WINS name resolution requires NetBIOS over TCP/IP services. Select one of the following options to configure WINS name resolution using NetBIOS:
        • If you use DHCP and dynamic addressing, you can get the NetBIOS setting from the DHCP server. Select Default: use NetBIOS setting from the DHCP server.
        • If you use a static IP address or the DHCP server does not provide NetBIOS settings, select Enable NetBIOS Over TCP/IP.
