Xerox WC 7830 there is a problem with xerographic system
  • omni
    • 30
    Hi All. We have got a message on UI " There is a problem with xerographic system " . Does anyone have this issue yet ?
  • devontug
    • Apr 2015
    • 99
    Re: Xerox WC 7830 there is a problem with xerographic system
    Could be your charge corotron check your error code
    • vodo
      • Dec 2016
      • 36
      Properly one of your CRUM chip did not engage. Check your CRUM chip on its drum one by one.
      • Exok
        • Jun 2011
        • 750
        Go to your supplies page. Select "other" supplies to show you how much life is left on your drums. This will show you what one is giving you a problem. Black, Cyan, Magenta, Yellow. All 4 drums are identical and can be swapped with one another. If one of the drums is displaying an error and the others are not, swap it with one of the working drums. If the problem follows the drum (for example if the cyan drum is showing the error and you swap it with the black drum and now the black drum slot indicates the error) order and replace the drum. If the problem stays with the same slot your problem is more complicated.
        • omni
          • 30
          Thanks everyone. The cause of the problem was toner K CRUM. I canged the K toner cartridge.
