Workcentre 7556 in morning gets fuser error message
  • axyun
    • Aug 2007
    • 1323
    WC7556 get fuser error message in morning. After turning off and on it
    woks okay for rest of day until turning on next morning. I do not believe customer has a surge protector.
    I did not want to just order another fuser and then have same issue with new fuser if caused by something else.
    Your help and advice and very much appreciated. Frank/ActionPhotocopy
  • jhalfhide
    • Apr 2015
    • 454
    Re: Workcentre 7556 in morning gets fuser error message
    Fuser motor stall error?
    If so, replace fuser and all will be fine
    • axyun
      • Aug 2007
      • 1323
      Thanks j. I will be there tomorrow morn and check out the errors etc. Frank
      • Jake2o
        • Dec 2007
        • 325
        Depending on where in the world you are it could be something as simple as the fact that the machine gets very, very cold overnight and then when it is turned on in the morning the fuser does not get up to its expected temperature within the time set so it throws up a fuser error.
        • jhalfhide
          • Apr 2015
          • 454
          Could be. The reason I went with stall error is because when we've had it (2 machines), it started out only doing it first thing in the morning. Reboot cured it but got worse over the next month and needed constant reboots until the fuser was replaced.
          • Jake2o
            • Dec 2007
            • 325
            Could be either at the moment error code should tell us more
            • axyun
              • Aug 2007
              • 1323
              error was fuser motor error as suggested by Jhalfhide. It was error 310-330 and only in morning. i replaced fuser day before yesterday and will call customer later today to see if machine turned on without error in morning. i figured if it was fuser motor drive then it would happen at other times as well. Frank
