Xes 6605 wide formart printer
  • Mukasa
    • May 2015
    • 178
    Please could help, after re-installing the recovery
    AccXes CD for the Xerox 6605 printer controller the machine can' print,scan,copy .
    It does not turn on the fuser and User interface.
    It started by loosing network connections by failing to log on its WEB PMT
    what can i do in the two situations or what are the instructions to install the OS software.
    Does any one have the full controller software for XES Xerox 6605 printer for new installations.
    Regards
    Godfrey
  • xcopytech
    • Aug 2006
    • 1792
    You need two cd's
    First one is OS
    Second one is 6605 accxes
    • Mukasa
      • May 2015
      • 178
      Re: Xes 6605 wide formart printer
      Originally posted by xcopytech
      You need two cd's
      First one is OS
      How can i get these two CD's and how much?
      My email : mukasa_godfrey@yahoo.co.uk
      • Mukasa
        • May 2015
        • 178
        • technogeek2009
          • Mar 2011
          • 167
          To add a little clarity to the answer, there are several steps in the recovery process. For all of these, having the AccXES controller service manual would walk you through the process step by step.
          Once you recover the hard drive, the printer firmware needs to be installed. You may download the firmware from Xerox's driver site:
          Xerox 6204 Wide Format Printer Drivers & Downloads
          Once the firmware has been installed, you will need to reinstall the feature keys. Go to the Xerox feature key website, and use the option "Replace all keys after software upgrade"
