Good day, have a xerox 700, very strange problem, the printed image would have a serious skew on the short end, (lets say 12x18 - the 12 side) I changed the registration transport and same thing. This is happening from every tray, I also notice that when the paper is fed through, (lets say it jams) and I see it before it reaches the BTR, but passes the registration area the paper looks slanted, I also changed my rollers that are before the registration, the 2 rubber looking rollers, any idea what could be causing all the paper to come in slanted? thanks
xerox 700 skew issue
Tags: None
Re: xerox 700 skew issue
it is older than 300k, but why would the paper be transferring slanted before it reaches the 2nd btr? before the paper hits the 2nd btr, you can see it slanted if the job were to jam for some reason, the paper is slanted from the registration assembly.Comment
