Xerox 7655 Yellow Lines and Desaturation
  • themountainecho
    • Dec 2011
    • 43
    Hi All,
    I'm having a problem with yellow lines and lines of yellow desaturation on one side of my prints. Swapped the M and Y drums to see if that was the issue but nothing changed. The issue happens when doing copies of a blank page as well.
    If anyone could point me in the right direction it would be really appreciated.
    Thanks in advance,
    Ken
  • adriansto
    • 2392
    Re: Xerox 7655 Yellow Lines and Desaturation
    These lines appear only when you make copies or it is visible also when you print from computer ?
    • themountainecho
      • Dec 2011
      • 43
      It happens when printing as well. The blank page was a copy, the rest have all been prints.
      • themountainecho
        • Dec 2011
        • 43
        Just a bump in case anyone has any ideas?
        • Reeves
          • Apr 2012
          • 297
          check the yellow developer unit they its either there is a portal or developer is low
          • Old Xeroid
            • Mar 2017
            • 5
            After removing the yellow drum you can remove two screws and then carefully lift the developer top cover. You will see the blockage if that is causing the defects.
            • themountainecho
              • Dec 2011
              • 43
              Thanks a million guys! All sorted thanks to you
