Xerox WC 7556 fault code 310-330
+ More Options
Posts
  • Mukasa
    • May 2015
    • 178
    Hello,
    This machine xerox 7556 displays " please wait machine adjustment in process......... system error has occurred call for assistance ".
    When you check in the fault history it is 310-330 ( fuser motor failure ).
    I even checked the fuser asy in another machine it was working ok .
    When i re-installed the machine software it worked that dayvery well but in the morning it was back to the same problem error.
    I need help
    Muks
  • adriansto
    • 2388
    Re: Xerox WC 7556 fault code 310-330
    Read once again, carefully, the repair procedure for 310-330 error code.
    It's about fuser drive motor assy
    • MrXerox
      • Sep 2010
      • 76
      Put some plastislip grease on fuser gears and the gears that mesh with it, if that doesn't work than prob fuser drive motor.
