Xerox WC 5855 Finisher Communication error.Check cabling
  • htcleo
    • Oct 2016
    • 4
    [Misc] Xerox WC 5855 Finisher Communication error.Check cabling
    Hi every one.
    Xerox Wc 5855 got serious problem with finisher by accident.So the finisher can not use anymore.But after removed it out the 5855 got a message"Finisher Communication error.Check cabling...."Anyone knows about this stuff,please help me.I have already done upgrade to 073.190.075.34540 throughtaltboot procedure.
  • prismtech
    • May 2014
    • 199
    Re: Xerox WC 5855 Finisher Communication error.Check cabling
    If you are running the unit without a finisher, where is the paper going to go? On the floor?
    Sent from my SM-J120W using Tapatalk
    • htcleo
      • Oct 2016
      • 4
      Thanks.But I have solution on where the paper going.I need help to WC 5855 working stand alone.
      • prismtech
        • May 2014
        • 199
        5855 requires finisher or at minimum offset catch tray. No finisher, no print.
        Fix finisher and put it back on.
        • htcleo
          • Oct 2016
          • 4
          It was not helpfull very much,but thanks anyway.
          • Exok
            • Jun 2011
            • 750
            Without a finisher or an OCT (catch tray) installed, you will get this message. This machine requires feedback from either unit to be input on the connector where they attach to the machine. The only way to bypass it is with a jumper installed. I know these can be ordered from Xerox for service techs but I don't know if they are available for sale elsewhere.
            • MrXerox
              • Sep 2010
              • 76
              Yes, xerox makes a finisher bypass tool but i make my own. See the attached pic, i take a paper clip and cut it to give it three points and then use electrical tape to hold together and jump the three holes in the pic. Thats it, it will work without a finisher.Screen Shot 2017-04-06 at 1.55.57 PM.jpg
              • htcleo
                • Oct 2016
                • 4
                Thanks to Exok and greatly appreciate to MrXerox.You are really genius.Follow the instruction,I made a jumper between pin11 & pin 13.Now my WC 5855 working fine without finisher(Because it was highly damage).
                Ps:Sorry for my bad English
                • efe311
                  • 114
                  i need diagnostic mode for xerox wc5855 please
