xerox 700 error code 077-311
  • Mukasa
    • May 2015
    • 178
    i have a xerox 700 with a code 077-311 that is really challenging me .It talks of the inverter system of which we have changed from a working machine.
    when you test the inverter nip motter in diagnostic it makes a vibrating noise and the motor does not turn .I have also changed the iot driver no result.
    what can i do.
  • adriansto
    • 2387
    Re: xerox 700 error code 077-311
    There is error in edoc. Nip sensor is in
    PL 10.6 item 14.
    Rezistence of the nip motor = 1.3 ohm
    • Mukasa
      • May 2015
      • 178
      PL 10.6 item 14.
      Hi My friend,
      thanks for the tips .
      I have gone ahead and replaced the exit inverter assembly and IOT driver Pwb from a working machine but the fault didn't clear,
      the inverter motor still make vibrating noise while warming up with fault code 077-311.
      Muks
