Bustled Fiery X3ety with Xerox DC250 - Fiery installation disks needed
  • chilldo
    • Aug 2025
    Hi everybody,
    few months i bought used Xerox DC250 with Fiery X3ety backmounted controller.
    Everything worked fine, until today. Everything looks normal, but i cant connect trough network.
    In DC250 system settings, network menu is gone.
    I connected keyboard and monitor, tried to reset bios, but in every case, i got linux booting starting linux kernel. Codes on back LCD comes to 00,
    but system seems to freeze.
    I hope that someone will help me with uploading installation files, and prevent me from breaking trough deadlines
    I would like to start first with reinstallation, than if fails again, proceed with testing ram & hdd.
    Thank you in advance
    Best Regards,
    Ildo
    Croatia
  • adriansto
    • 2388
    Re: Bustled Fiery X3ety with Xerox DC250 - Fiery installation disks needed
    If your monitor display this on most of the situations the Fiery software is corrupted.
    But also is a good ideea to check the hdd for bad clusters
    • chilldo
      Hey guys, finally i managed to get those disks.
      In the meantime. i checked ram and hdd, and tests showing that everything is fine.
      So, i presume that fiery file system or similar got corrupted.
      Now, i thinking about next steps;
      i found manual for Installing or Updating Fiery System Software
      • tbyabachwezi
        Engineer
        • May 2017
        • 24
        Hi. have you solved your problem? coz I had same problem but I managed to install the software with the steps explained on the CD
        • InterfaceP
          • Jun 2013
          • 488
          You need the USB Prep tool. PM me if you need it.
          • dataservice
            • Jun 2017
            • 5
            i guys, i have the same issues with an xerox docucolor 242 with fiery controlloer.
            i need disk to reinstall it, can you help me?
            tnx bye
            • adriansto
              • 2388
              Check Fiery hdd first.
              dc242 Fiery is more robust than dc250
              • dataservice
                • Jun 2017
                • 5
                but if the hdd is breacked or the system have issues i need to reinstall the system
                now i maked a test of hdd, after finish tell you
                • chilldo
                  tnx bye
                  What issues you got?
                  On end i had MB failure, network chipset was burned down.
                  Ordered used one from ebay for around 100$, now waiting
                  If U need disks or some tools PM me, i can upload ISO's on my drive.
                  Just let me know results from HDD test
                  • dataservice
                    • Jun 2017
                    • 5
                    hdd test finish, hdd is good!
                    and now???? can you help me please????
                    • dataservice
                      • Jun 2017
                      • 5
                      Hi Chilldo, the hardware seems to in good state, the hdd is good, i attempt to check the file system, if you can take me a cd thanks you, now send a pm
                      • chilldo
                        Can you see network configuration on machine display under settings menu?
                        • dataservice
                          • Jun 2017
                          • 5
                          No
                          • Dterrell
                            I have an DC252 with the same issues. No network connetivity and no "Network Settings" on the on 252 Control Screen?
                            Where is the procedure to testing the HDD? And where or who is a source for the Software? I'm not necessarily looking for a FREEBE, but Xerox is suggesting I just buy a new machine.... NOT!
                            Dterrell
                            • adriansto
                              • 2388
                              You can hook monitor on Fiery and watch booting process when the Fiery start.
                              What you see on photo is Fiery software corruption.
                              For hdd integrity you can check it on Linux PC.
                              For Fiery system software cd's you can send me mail at stoadis@gmail.com
