Xerox 7535 scanner fail
  • surfkid
    • Nov 2016
    • 8
    Hi,
    I have a xerox 7535 with this error 362-310-00
    Scanner communication fail
    Can help me?
  • Mukasa
    • May 2015
    • 178
    Re: Xerox 7535 scanner fail
    Originally posted by surfkid
    Hi,
    Can help me?
    hi friend,
    Communication cannot be established between the IIT PWB and the SBC PWB.
    NOTE:
    When turning the power OFF, turn OFF the Power Switch first and then the Main Power Switch.
    Cause/Action
    1. Turn the power OFF and ON.
    2. Turn the power OFF and check the following:
      • The connector ( P/J309) between the SBC PWB and the BP PWB for damage and foreign substances
      • The connection between the BP PWB and the IIT PWB P/J7192 for open circuit, short circuit, and poor contact
      • The connectors of the BP PWB and the IIT PWB P/J7192 for damage, foreign substances, bent connector pins, burns, and improper soldering on the PWB
      If no problems are found, replace the following parts in sequence:
