apeosport
  • haxan
    • Apr 2016
    • 4
    [Error Code] apeosport
    Error code 016-749 refused to go off even after installing the right drivers
  • shinchan
    • May 2011
    • 197
    Re: apeosport
    May I know what file are you printing? PDF?
    if PDF, you can try printing using other pdf reader. Try using foxit pdf reader.
    the computer OS is windows / mac os x?
    if mac os x, are you using postscript driver?
    if postscript driver is used, please check the machine have postscript card installed.
    otherwise use normal PCL driver
    • haxan
      • Apr 2016
      • 4
      Re: apeosport
      Thax its a test page
