Xerox 5632 Scanner failure, 3.3v reading over 3.5v
  • ITMonkey
    • Oct 2015
    • 8
    [Electrical] Xerox 5632 Scanner failure, 3.3v reading over 3.5v
    Hi everyone, i am hitting a wall here. first off i am not xerox trained, i have a workcentre 5632 that has recently been throwing problems with the scanner which we use very frequently. I have been getting the following messages non stop no matter what i have done. i have tested down to the voltage on the PWB in the image processor tray and the voltages coming to that are reading high (3.5v+) for 3.3v lines.
    14-563.00 Scanner needs service
    14-560.00 Scanner is calibrating, please wait.
    14-562.00 Adjustments in progress...
    Also the following in the event log:
    03-320
    14-710
    14-110
    03-777
    Currently running system software 21.113.02.091
    Any help would be greatly appreciated. this machine has me feeling very defeated at the moment.
  • Enzo
    • Jul 2009
    • 413
    Re: Xerox 5632 Scanner failure, 3.3v reading over 3.5v
    Check the strap to slide the scanner. He gave me that mistake because he was frayed.
    • ITMonkey
      • Oct 2015
      • 8
      All cables are fine, no fraying or broken wires anywhere i can find. I am getting 3.5v coming up from the LVPS. Do you think it could be the LVPS going bad?
      • adriansto
        • 2387
        The voltage is ok.
        It not comming from LVPS.
        Replace the white flat cable from carriage.
        If that not work you will need replace scanner assy.
        • ITMonkey
          • Oct 2015
          • 8
          Originally posted by adriansto
          The voltage is ok.
          By Scanner Assy. you mean the scanner PWB or the CCD?
          • adriansto
            • 2387
            All assy scanner. You cant align the CCD. In fact the problem is located in ccd pwb.
            • ITMonkey
              • Oct 2015
              • 8
              So if the ribbon cable does not fix the issue then its time to pitch the machine. with it being so old I don't see the point in spending that much to fix it.
                +3.5 is no issue .. you are allowed +/- 3% of voltage. you have other issues.
                • adriansto
                  • 2387
                  You are right.
                  Or may be you find cheap second hand machine and make one good copier from two machines.
