Work Centre 7855 Jamming on double-sided ONLY
  • rsantner
    • Mar 2017
    • 3
    Greetings everyone,
    That machine keeps on jamming intermittently on double side print/copy
    In addition, I am getting the following jam codes 312-979-000, 377-106-000 and 312-979-000
    Your help will be greatly appreciated
    Cheers!
  • Flash
    • 378
    Re: Work Centre 7855 Jamming on double-sided ONLY
    The problem is being caused by the duplex motor. It seems to be happening more on the i machines. Replace the motor with a 75xx motor. You will have to remove some plastic around the motor for it to fit, It is slightly larger than the 78xx series motor.
    • rsantner
      • Mar 2017
      • 3
      Thank you for your reply.
      Actually I have swapped duplex units of like machines. However, the same problem still persists.
      Any more recommendations?
      • copytech200X
        • 264
        Any solution for this paper jam?
