Xerox Colorqube 93-536-00
  • LamsterPaul
    • May 2014
    • 46
  • prismtech
    • May 2014
    • 199
    Re: Xerox Colorqube 93-536-00
    I've seen these things blowup a million different ways but "heating too slow" is a first.
    Replace upper umbilical or tubes as you call them. Report back.
    You could also call RJ at dotcomliquidations and he would selling you a whole marking unit for 150 used. Plus frieght. Say James from Canada sent you.
    I don't replace any "tubes" or reservoirs any more I just slap in a different one complete. Too much of a time waster.
    Sent from my SM-G903W using Tapatalk
    • LamsterPaul
      • May 2014
      • 46
      The umbilical kit has solve the problem, looks like there was a hole inside,
      i have also see some, leaking color on the lower printhead at the connector,
      looks like, that i need to replace the printhead soon or the lower umbilical kit is also no bad
      replacement
      • prismtech
        • May 2014
        • 199
        replacement
        If it's leaking at the connector it usually indicates the print head has been removed after initial install.
        It's a 50/50 crap shoot as to whether a used head will reseal with the umbilical.
