finisher error
  • Dytommy
    • Jul 2025
    [Error Code] finisher error
    After initializing the NVM on a xerox 7775 computer, it marks me error in the terminator, before initializing the NVM the computer worked with the finisher, consider at first that it was a bad connection of the cables but it is not so, if I I open the door of the finisher the computer warns me that it is open, according to what I have been told is that this equipment should be assigned some value in the NVM, I used the manual of the XWC7675 but it is not very helpful to me, someone who has the PWS and give me a hand
  • InterfaceP
    • Jun 2013
    • 488
    Re: finisher error
    • 763-012
      • 0 = without Booklet Maker (Advanced Finisher)
        1 = with Booklet Maker (Professional Finisher)
    • Dytommy
      Re: finisher error
      Originally posted by InterfaceP
      • 763-012
      A question that is the value of the NVM that uses the XWC7775 ?, I will do the test and then the story, thanks in advance
      • Dytommy
        Re: finisher error
        • 763-012
        Thank you very much, your answer was very accurate, good contribution
