xerox 700 077-311
  • lion_heart
    • Jun 2014
    • 174
    xerox 700 077-311
    good day, have a 700, 077-311 wont get past that, any suggestions? thanks
  • adriansto
    • 2383
    Re: xerox 700 077-311
    Front door interlook or inverter nip release sensor PL10.6 item#14 or inboard plastic link from fuser decurler is broken or bad invertor release motor.
    • lion_heart
      • Jun 2014
      • 174
      ok, thanks, will try one by one, amazing thing is sometimes i get this error, i would turn machine off, pull the whole fuser assembly out, with the 2nd btr and registration assembly and just push it back in and turn machine on and it clears, for some reason it wouldn't clear this time, and also, it mainly only happens if I have a jam or a next reason to open machine door when a job is running, when i close the door this pops up. Will let you know my findings. thanks
      • adriansto
        • 2383
        I presume you did checked to have clean contacts on fuser connector also backplane connector
