377-131
  • Reeves
    • Apr 2012
    • 296
    [Error Code] 377-131
    I have a Xerox we 7535 its working okey single side but double sided its jamming in the duplex I checked the duplex drive motor in diagnostic mode the motor is not working I replaced wit a new motor the problem is still there what could be the problem please advise
    Re: 377-131
    if it's not the motor .. check the cable for kinks cuts.. then it would be a driver board
    • shaahin
      • Jun 2017
      • 26
      Re: 377-131
      Check the following:
      • A paper transportation failure due to a foreign substance/burr on the paper path
      • Each Duplex Roll and Pinch Roll for contamination, wear, and revolution failure
      • Each Exit Roll and Pinch Roll for contamination, wear, and revolution failure
      • Each Duplex Roll Drive Gear for wear and damage
      • Each Exit Roll Drive Gear for wear and damage
      • The Exit 2 Gate for operation failure
      • Use of paper out of spec (Refer to the spec in Chapter 6 General)
      • The Duplex Wait Sensor for contamination, improper installation, and Actuator operation failure
      • The Duplex Wait Sensor for failure: DC330 [077-108] ( PL 14.5)
      • The connection between the Duplex Wait Sensor J175 and the MD PWB J523 for open circuit, short circuit, and poor contact
      • The Duplex Motor for revolution failure: DC330 [077-073] ( PL 14.5)
      • The Exit 2 Drive Motor for revolution failure: DC330 [077-062] ( PL 17.4)
      • The Exit 2 Gate Solenoid for failure: DC330 [077-003] ( PL 17.5)
      If no problems are found, replace the following parts in sequence:
