Xerox wc 7120 error code 042-345
  • vinayforn
    • Jun 2025
    [Error Code] Xerox wc 7120 error code 042-345
    Kindly help me sort out this 042-345 error code
  • shaahin
    • Jun 2017
    • 26
    Re: Xerox wc 7120 error code 042-345
    An abnormality was detected in drum coupling contact/retract
    check the following
    . the transfer unit for mechanical loading or damage
    . the drum coupling contact/retract for loading and drag
    . 1st BTR contact/retract operation 94-003 contact, 94-004 retract
    . check wire fc and k drum sensor and mcu pwb
    . fc drum sensor 42-101
    . k drum sensor 42-102
    . main drive motor revolution failure 42-006
    • xeroxsharp
      • Nov 2008
      • 270
      Drum R1 or R2 or R3 or R4 is faulty.
