Hello
l need some help
l have a 7220i where l changed a cable scanner.l made the various setting in EDOC and now l find myself with a reduced image of more than 1 centimeter on a A3 in vertical direction.
l tried to change the NVM value ( 715-051 Vertical magnification adjustment) but it's impossible!!
l have the message " NVM write failed" , l specify that: if l try to change a NVM value of registration for exemple, the new value is written correctly ( no error).
do you know this problem?
l need some help
